Results 1 to 7 of 7
Thread: Front panel
    Aug 2008
    blackpool
    3,415
    Default Front panel
    I've just looked inside my front arch and noticed the front pal don't look like it's fitted to the front leg. The other side is the same. It looks the original one. Can anyone confirm theres is the same. Will get a pic up in a bit. Thanks
    Aug 2008
    blackpool
    3,415
    Here's a pic of what I mean.
    Aug 2008
    blackpool
    3,415
    Sorted found out they are like that looking at others.
    Aug 2006
    I live inside your pants
    4,527
    So is the pic correct or should it be welded?
    Aug 2008
    blackpool
    3,415
    Looking at others it seems to be right.
    Jul 2008
    Unknown
    9,635
    It's not welded on there from the factory, the bits welded are the crossmember ends and front edge of the headlights and the reason is it's just a filler section for the wings to bolt too. You'll know this if you replaced the front panel
    Aug 2008
    blackpool
    3,415
    Ok cheers. No not changed a front panel before this is the original one just wanted to check.
