Results 1 to 4 of 4
Thread: 1.6 Gte power loss!
    User Mboasty's Avatar
    Feb 2008
    277
    Default 1.6 Gte power loss!
    Hi, my gte has lost power sound like a scooby
    but without the go! Popin from the exhaust on idle
    have changed leads, plugs fine, checked timing.
    had suspected the coil at fault, but tried the one off my Xe,
    still same problem. Starts fine.
    Any ideas anyone?
    cheers
    matt
    Club Member Club Member Jonesfach's Avatar
    Feb 2014
    Wrexham
    573
    Sounds like it's running on 3 cylinders?
    oil and water all ok?
    Club Member Club Member CorsaBBoomer's Avatar
    Oct 2006
    Belgium
    396
    Is one of the plugs wet? Then you can point on which cyl. you can start looking.
    GTE is with the dizzy, maybe start looking in the cap?
    Opel Corsa 1.6 Michalak 1986 : http://www.pngclub.com/forum/showthr...ect&highlight= Yes, it's a convertible with a hard-top!
    Opel Corsa 1.0 1983 "Josefien": http://www.pngclub.com/forum/showthr...ien&highlight= Miss I-Went-International
    Opel Corsa B 1.5TD 2000 "Bertha"
    Citroen AC4 1929 "Clarice"
    Feb 2007
    16,486
    Sure the leads are on right?
