Anyone know where I can get disks predrilled for the 4 stud nova?
cheers
cheers
eBay do v6 discs already drilled out for four stud
Or buy the 280mm Meriva discs they are already 4x100
http://m.ebay.co.uk/itm/191495284925?_mwBanner=1 will 284mm corsa d brakes fit?
ordered some from LMF, £99 inc. postage, Blank late calibra turbo 288mm discs redrilled (centre bore 70mm, already got 70mm spigots on atm), hopefully they're Blueprint but i highly doubt it as the guy on the phone said they usually do Delphi aha
I've just fitted a disc, (yet to do the passenger side without moving the car out.) 288mm Lotus Elise S2.
These are 4x100 pcd, centre bore is the same, but seems about 2mm larger.
To get over this I squared the disc up with using the 4 wheel bolts to nip the disc into place then tighten the screw.
NovalutionGSi - Donkey Kong In a Go-Kart
