Results 1 to 6 of 6
Thread: Storing an engine
    May 2013
    norfolk
    333
    Default Storing an engine
    Hi guys what's the best way to store an engine possibly long term. It's an e16se am I right in saying your suppose to remove the spark plugs and pour a bit of engine oil in and then keep turning it over once in a while
    cheers guys Rich
    Aug 2008
    blackpool
    3,415
    Iam in the same situation pal. I rebuilt my e16se last year it won't be going in any time soon. All I have done is put fresh oil in and turn it over by hand every couple of weeks. Just hope and prey all is well when she goes in .
    User Club Member
    Jan 2007
    brynmawr south wales
    1,223
    I leave spark plugs in less moisture to corrode the bores just spray a load of wd40 over everything
    Feb 2007
    16,486
    Aslong as the plugs are kept in it will be fine.
    May 2016
    loch lomond
    144
    Fogging spay is what you want for the internals or marvel mystery oil don't use reg oil as it is not designed for storage uses!!!
    I use Vaseline for external surfaces for long term storage heat it up in the microwave & brush it on it will never rust
    May 2013
    norfolk
    333
    Cheers guys leaving the plugs on makes sence regarding moisture. It's been out 2 years and still turns over so should be fine
