What would be the better for the road?
Running 2.0 8v on carbs.
I know the Golds say for track use but im guessing they would be a slightly better option and more durable?
Or any other options???
Sent from my SM-G920F using Tapatalk
Be careful with track use stuff on the road, some track brake calipers don't come with seals for example.
I'm using Gaz, I think they are GHA's,on my road legal track car and find them really good.
I'm not sure a road car would justify the extra money for golds over the gha's
Can't see the benefit of golds for road use. Save the money and use GHAs
I'll be using the GHAs as well, plenty of people use them and I've heard nothing but good things.
Probably because the Guys behind Gaz used to work for Leda
Thanks looks like ill just get the Gha's.
Are the alloy top mounts worth geting?
Yep
Do you not need to modify the shock towers to fit the adjustable tip mounts?
Nope - well you do if you go eccentric, rather than concentric (or may be the other way around )
Even then you can still fit them. Just won't have loads of adjustment.
