Hey guys, I'm wanting to gain some castor as when I last checked on the hawk eye at work it was almost 0degrees, ok the car was quite low and not how I would use it for any race type events. Plans are to raise it a half inch and recheck my geometry anyway.
So, if I shaved some off the poly bush between the tie bar to front cross member bracket, will this be sufficient to pull the lower arm forward a bit and gain that important castor?
thanks
brucer
