Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Reviving after 6 years.
    User Club Member N0V4 JACK16's Avatar
    Mar 2010
    Preston lancashire
    287
    Default Reviving after 6 years.
    Hi guys
    I'm hopefully going to get my old sr going after 6 years of being in storage. I've never worked on a car thats been stood for such a long tine so how to i go about it?
    Fluid change obviously but do i check the fuel tank before hand? For corrosion? etc
    Also will the motor be ok? The car has been inside for the whole time its been dead but never started.
    Any advice is greatly appreciated.
    Cheers.
    Sent from my LG-H850 using Tapatalk
    Jul 2008
    Unknown
    9,635
    Remove the spark plugs and spray a bit wd40 and turn over by hand to make sure it's not partially seized, drain the tank and fill with fresh fuel, change the oil and filter and once it starts don't rev it until it's warmed up a bit
    Club Member Club Member nova_niek's Avatar
    Aug 2007
    Lelystad, NL
    1,108
    Brake fluid definitely needs refreshing. Make sure brake caliper pistons aren't seized.
    If you go to spray WD40 in the bores, let it sit for a day before rotating the crank manually.
    New spark plugs, fresh battery and you should be good to go.
    Oh and check the tyres - chances are they are cracked from sitting a prolonged period.
    sent from my Nokia 6310i using the keypad
    One day I'll start a build thread. One day...
    Club Member Club Member Nova00's Avatar
    Jun 2009
    Manchester
    984
    Always good to see another white SR around here. Hopefully you will get it to the meets.
    Nova SR 1.4
    Mar 2010
    Preston lancashire
    287
    Thats the plan. It should be out and appreciated rather than just stored away. Hopefully it should spring back to life with a little bit of work.
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Suspension damper seals might be easily irritable after all that time, take it easy for the first hundred or so miles after doing the fluids etc
    Oct 2009
    aberdeen
    2,892
    I rebuilt and started one of my minis after it lay 10 years, 5 years of which were outside. I checked it would turn by hand, then tried starting it just to get it going. Took some fresh fuel mixed with the old to get it going but I wanted it warm so I could drain all the old oil. Once the car was put back on the road and serviced (new radiator etc etc), drove perfectly.
    Jun 2009
    Manchester
    984
    excellent
    Quote Originally Posted by N0V4 JACK16 View Post
    Nova SR 1.4
    User chris gsi's Avatar
    Sep 2005
    gloucester
    1,284
    The one thing I would do is change the cambelt and water pump as it would have gone brittle having sat in the Same position all this time and the last thing you want is that snapping
  10. #10
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    I recently had an xe that sat for 17 years... I checked it by hand, put a bit of oil down the bores and she fired straight up! (I did have to run it on easy start and the fuel pump had seized though )
