im breaking my let nova
apexi boost controller 330 Ono
revolution rl7 wheels 15" got 5 of them 450
gaz coilovers never seen the road 350 Ono
eccentric topmounts (are off djbrowneys nova)100
cav internal shifter 30
rosejointed linkage 35
wilwood midilites 300
Etb instruments dd2 digi dash 380 Ono
quaife quick rack 100
strengthend bottom arms 4
rally design bias pedal box120
braided brakelines 60
equal legnth driveshaft setup,with m-tec shaft,new cv joints 200 needs new cv boot on both hub side joints got ripped when taking engine out
rear disc beam 120
big block hubs the propper ones 280
chris astley solid engine mounts,including f28 mount 120
strengthend rear gearbox mount,done by paul 30
now the shell
The shell is a 1.2 sxi 1992 on a k plate
It's got front strengthening plates welded on and seam welded around the front and strut tops,boot floor has been cut and and a plate made up and welded in,had to new front arches the rears are mint,still the original ones,front crossmember has been cut to allow for intercooler,also the slam panel had been cut to for easier access,the car has been painted inside and out ford moonstone blue,there's a little rust patch that I found in the boot on the tight hand side usual place,got glass windows alround also has a 6 point omp cage...front needs refitting
want 700 Ono
ive got no v5 for this but will pay to get a v62 if needed cheers
Please contact me on 07572421794 as don't come on here much
