Results 1 to 9 of 9
Thread: Rear arches
    Aug 2008
    blackpool
    3,415
    Default Rear arches
    Got my new repair panels inner and outer. I've being reading through previous projects and noticed people not repairing the inners and making them single skinned as last longer. Any one got any pics of what they have done with theirs?
    User Club Member nova_pipi's Avatar
    Nov 2008
    Manchester
    520
    A lot of people have used two outer skins as an inner and outer so the match up well.
    I got an inner and outer for mine for both arches and one side fit well but the other didn't as in the inner arch was a slightly different shape than the outer
    Nov 2008
    Manchester
    520
    Sorry I've not got any pictures to hand as there not on photobucket
    Jan 2004
    Ash vale, Hampshire
    1,471
    I had to cut my inner repair panel into three sections to get it to line up with the outer repair panel.
    I cant really see how you can single skin the rear arch unless you mean make the inner Panel join a bit higher up in the arch.
    Apr 2011
    wiltshire
    1,938
    I'm just doing one now. I have just made the inner up out of steel and tacked it to the outer up high. That's an accident repair on a competition car but I would say if its a decent model do it properly.
    Aug 2008
    blackpool
    3,415
    Ok I've welded in the inner now so will do both sides the same might aswell. Cheers
    Aug 2008
    blackpool
    3,415
    Struggling to get the outer welded on. I've tacked it on but cos the panel is so thin kept blowing holes even with the welder turned right down. So I've cut it back off as was knackered by the time I'd finished. That's one wasted!.
    Apr 2011
    wiltshire
    1,938
    As long as the gap isn't too big you should be fine, just point the tip at the previous weld. Don't do more than one or two welds in the same place, keep moving.
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    i did the Craig above, i cut the rust off, cleaned it all up then spotted what was there on to the outer, for more clearance.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
