This has prob been asked before but are the bearings on a 1.2 nova different to the bearings on a gte/gsi?
No, they list corsa b ones with nova ones for some reason
All Nova ones are the same, from memory there are two sizes that are listed, 64mm and 66mm from what I can remember it's the smaller ones you want.
Cheers lads, can corsa hubs fit a nova?
They'll fit, 90% sure there the same although I remenr something about a ball joint but that may be the corsa lower arm I'm thinking of
I believe there are two different sizes, 64 and 66mm as mentioned before. Am I right in thinking the diesel hubs are different to the petrol hubs?
Cheers lads, I'm trying to see wot hubs there is that fit a nova and have the biggest size of bearing as I'm searching threw bearing just to see if there is a way of five studding the nova with out machining the hubs, I know this is a very big long shot and someone has prob tried it but I've not seen anywere that anyone has tried so I'm thinking if it works it would make five studding very easy,
