Results 1 to 10 of 10
Thread: 4 pot brakes
    Newbie
    Jun 2016
    south wales
    13
    Default 4 pot brakes
    I have a 1.4 rally nova with 1.5d front brakes, would like to upgrade to 4 pots are there any calipers off another vehicle that would fit even with a modified bracket,rgds Pete
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Do you run small or big wheels?
    Some Mg's come with 4 pot AP calipers, but they are large as the discs are 310mm...
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    Club Member turbojolt's Avatar
    Jan 2007
    derbyshire, derby, shelton lock
    10,358
    Speak to RallyMarshal iirc he was advising a couple lads to use 256mm ate brakes with larger discs rather then cheap 4 pots, tbh if I was you I would try and be his best mate the guys a fountain of knowledge and he competes in rally events
    ^^^ did you just read that? what a idiot ^^^
    PROJECT 2 FAST 2 FAT clicky
    ''lifes what happens, while your busy making plans''
    Jan 2015
    Malta
    712
    https://www.amazon.com/ACDelco-172-2...9f6ea98b1d32d2 these are fairly large, but also fairly on the cheap side, especially since they're a Cadillac part.
    Newbie
    Jun 2016
    south wales
    13
    Running 14 inch
    Newbie
    Jun 2016
    south wales
    13
    Quote Originally Posted by turbojolt View Post
    Cheers for that, rgds pete
    Oct 2011
    358
    If your running 14" then you have a couple of size limitations on the calipers etc.
    Until this year Ive run the standard Astra GTE 16v 256mm ATE calipers - originally ran them on 256mm discs (which will fit under 14" wheels) and then used a modified Cossie 285mm disk and adaptors to give a bit more braking. The key is the pad. I personally use Mintex F4R pads and find them the dogs danglies. Have tried DS3000s but didnt get on with them. Are you stage or road rallying?
    Paul..
    Newbie
    Jun 2016
    south wales
    13
    single venue stuff
    Oct 2011
    358
    Then try some F4R pads in the standard 16v ATE sliding caliper with new discs (i prefer grooved not drilled but standard Mintex ones are fine too) and bed them in properly prior to an event. Use proper brake fluid (Motul RBF 600 or 660) and you will find they give a decent brake pedal with a good bite once they have a little heat in them.
    Paul..
  10. #10
    Newbie
    Jun 2016
    south wales
    13
    Thanks for the advice Paul its really appreciated, Pete
