Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Track day advice
    Senior User Asa-James's Avatar
    Nov 2006
    Cheshire
    3,973
    Default Track day advice
    Any and all appreciated, doing my first one on Saturday at Oulton Park. Taking spare tyres and brake pads, anything else I need to think about?
    User Club Member
    Nov 2012
    Pwllheli, North Wales
    468
    Oil
    Water
    Brake Fluid
    Tools
    Jack
    Axle Stands
    Driveshafts?
    Torque Wrench
    Tyre Pressure Gauge
    Compression Tester
    Battery Drill
    Multimeter
    Some wire, crimps, bulbs, spare switches, fuses, relays etc.
    Few nuts & bolts of various sizes
    Tap & Die set
    I'm not a track'er but that's sortof the minimum I'd take to a rally
    I suppose it depends on, if something breaks, do you want to be able to fix it and get back out or will you put it on the trailer and go home? Also, if you know of any parts that your car might need out there then obviously take them with you.
    Also, on a rally, there is a mindset of - keep the car going at all costs, so some would take a welder with them, helicoil sets, spares of absolutely everything. On a trackday there's nothing much at stake so there's no harm in taking it home and sorting it at a later date
    Jan 2012
    s wales
    333
    The most important Cable ties
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Hope this works
    http://www.pngclub.com/forum/content...Trackday-Guide
    Its a little old but the basics are there.
    Basically have fun, dont try too hard and go home safe
    Club Member turbojolt's Avatar
    Jan 2007
    derbyshire, derby, shelton lock
    10,358
    Make sure your starter motor is firmly attached
    ^^^ did you just read that? what a idiot ^^^
    PROJECT 2 FAST 2 FAT clicky
    ''lifes what happens, while your busy making plans''
    Nov 2006
    Cheshire
    3,973
    Cheers guys, Stuart that was the link I was after but couldn't find! It's my daily Panda 100hp I'm taking, it's kept in fairly good shape so I'm hoping reliability won't be an issue, this car survived an autosolo last weekend at Wrexham (and won!)
    Ive got about three hours free today in between work/vet appointment/other shizzle to get it sorted for tomorrow
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    For standard road tyres definitely take a pump and pressure gauge and keep an eye on tyre wear. If they're wearing badly then reduce the laps right down. Check tyre temps when hot and adjust accordingly.
    Take brake fluid and be prepared to bleed through some of the front brakes at lunch, if it's standard fluid and you're hard on the brakes things may get warm
    When you pull into the pits don't put your handbrake on and jump out, leave it idling for a minute and then roll it forward and put it in gear when the engine's off
    Keep it nice and slow and smooth at first and build the speed up throughout the morning
    Make sure your starter motor doesn't fall off and has all the bolts in, good advice Leigh
    If you don't have a suitable helmet already grab a comfy one from a local shop.
    Nov 2006
    Cheshire
    3,973
    Four new tyres with pump and gauge going with me, brake fluid changed a week ago but taking more with a bleed bottle, new pads coming as well just in case, and I have a bike helmet I use for Karting so sorted there too. Just got to fit the tyres to my spare wheels, oil and filter and clean tonight
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Always remember your helmet.
  10. #10
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Make sure you have enough fuel.
    Seen two cars run out of fuel on the frigging track. One was a member on here...
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
