Results 1 to 5 of 5
Thread: Gearbox help
    Newbie
    May 2016
    Kent
    41
    Default Gearbox help
    Hi,
    i have an f15 gearbox and I need to replace the cluster. The f15 in the car has the mainshaft and pinion as one.
    The second hand cluster I have has a removable pinion. Both gear clusters have 3.94 final drives.
    The question I have can I keep the crown wheel in the car and used the other 3.94 pinion? I wasn't sure if the pinion and crown wheels were matched to each other.
    Thanks
    christopher
    Oct 2011
    358
    For the sake of another hours work, I would change the crownwheel too in case there is some wear to the cw/pinion already. Plus a gearbox oil change is not necessarily a bad thing.
    Im surprised your running a 3.94 - thought it would be a 4.2 or a 4.5 in yours.
    Paul..
    Newbie
    May 2016
    Kent
    41
    Quote Originally Posted by RallyMarshal View Post
    Paul..
    I was going to change it but, I was trying to save myself a job. This is in a corsa that I have built, which I use for autotesting and slaloms, not the Nova rally car.
    The Nova has a 4.8.
    I have a 4.5 CWP to put in the corsa, but with a standard gear cluster it is going to make 1st gear very low, which wont help me on grass.
    Christopher
    Oct 2011
    358
    Aha.. You on an F20 in the rallycar then?
    Paul..
    Newbie
    May 2016
    Kent
    41
    Paul..
    No, F15 quaife SCCR, with hockley diff and large side gears
