I have a '93 Nova 1.2i with C12NZ engine and am trying to find a suitable replacement in-tank fuel pump as mine has had it.
The cradle it's suspended from and pre-filter are pretty knackered too but I'm struggling to find suitable replacements. I could live with reusing the cradle and pre-filter but every pump I look at on the web that has a vehicle compatibility checker says its not compatible. Any advice appreciated.
Specs found online for original pump: Bosch 0580453509
In-Tank Fuel Injection Pump Kit
Fittings In (mm):- 8mm
Fittings Out (mm):- 12mm
Pump:- P3011.1
Voltage DC:- 12v
Flow Ltr/Hr (Max):- 150 Ltrs
Flow Ltr/Hr @ 2 Bar (44psi):- 60
Max Pressure (Bar):- 3.1
Length (mm):- 125mm
Diameter (mm):- 50mm
Weight (Kg):- 0.3
