Results 1 to 7 of 7
Thread: Filler Neck Rubber
    Sep 2010
    240
    Default Filler Neck Rubber
    I'm in need of the rubber hose that joins the filler neck to the tank if anyone has one please?
    Thanks
    Josh
    User Club Member
    Nov 2008
    Northern Ireland
    266
    Fuel hose in the right diameter just. Someone on here will be able to tell you the diameter.
    Aug 2008
    blackpool
    3,415
    I have one on my sr. Pm if intrested
    Sep 2010
    240
    Pm sent
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    When I did mine I ordered a 35mm inner diameter L shaped fuel hose from auto silicone hoses as the straight part of it is long anuff and works out a lot cheaper
    Sep 2009
    Teesside
    386
    Ours is 53mm ish and I am just getting a chunk of fuel hose with jubilees
    Aug 2008
    blackpool
    3,415
    Pmd
