Results 1 to 7 of 7
Thread: Distributor timing
    Senior User phunkynova's Avatar
    Feb 2010
    Neuburg a.d. Donau. Bavaria D.E.
    1,571
    Default Distributor timing
    Hi All
    I have a motor sport distributor in my rally car 1.4NV, normally it's fitted with a vacuum operated advance distributor but the motor sport one is none vacuum.
    Where should I be setting the distributor ie like the old one using a timing strobe light on the timing marks or should it be set up differently.
    Thanks.
    Hertford
    2,069
    Best place to do this is on a rolling road. iirc you set the timing without the vac line connected on a std car.
    Feb 2010
    1,571
    Yes garyc but then a vac dizzy will advance as the revs go up and a none vac dizzy I believe will not so dose this mean it must be set more advanced or am I wrong ?.
    Aug 2006
    I live inside your pants
    4,527
    You are wrong.
    Base timing should presumably be the same as std. since its a race dizzy, im assuming additional advance is done with adjusted weights and or springs.
    If you had to gain 10deg by adding 10deg to your base timing then you very likely do not have a race dizzy.
    I have never understood removing of the vac feature. As this looses the '3d' timing ie referencing load and rpm to give a timing condition for a wider range of running variables.
    I get the argument for 'reliability' and how race engines run mostly WOT but... really?
    Oct 2009
    aberdeen
    2,892
    I had no vacuum advance on my 1.4 nv either. I experimented with it get the running best over time so I would guess a rolling road would be the best way forward?
    Aug 2006
    4,527
    ultimately, yes.
    Jan 2016
    22
    If using twin 40s then there is no vacuum outlet on the manifold, so with the old distributor then the vacuum is not used.
    With the timing gun set your timing at idle to 16°, this gives you the most advance later in the Rev range.
    Sent from my GT-I9505 using Tapatalk
