Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Wheel wobble (not eu chat)
    Oct 2009
    aberdeen
    2,892
    Default Wheel wobble (not eu chat)
    I am getting some wobble both through the steering and the body under hard braking, there is also an occasional small wobble detected on some roads when going downhill (ie no power on).
    The rear brakes have been completely overhauled as a cylinder was leaking but since then this wobble has started.
    I would have said it is brake discs (new 20k ago) but just seems to be a coincidence that it is just after doing the back brakes?
    Standard Nova
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    I would of said it was the front discs warped slightly, I can check them with a dti gauge but probley wouldn't hurt just to replace them
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Mounts, bushes, top mounts, warped discs.
    Senior User Club Member paul james's Avatar
    Feb 2003
    south wales
    2,038
    Did you put the rear hub nut on to the right spec? You don't want to over-tighten them
    Oct 2009
    aberdeen
    2,892
    Just had the MOT so assumed all bushes etc were fine (seemed ok when I checked them before the test too). I'll try new discs first and check bushes etc again, hopefully just bad timing regarding the rear brakes!
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    Try bedding them in again, you might simply have uneven transfer layer which feels like warping
    Oct 2009
    aberdeen
    2,892
    Quote Originally Posted by Stuart View Post
    Hoping not to sound stupid here, do you mean the new rear ones?
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Have you had your wheels balanced?
    Oct 2009
    aberdeen
    2,892
    Quote Originally Posted by Southie View Post
    Yes, it only started 2 weeks ago and is mostly just on hard braking.
  10. #10
    Oct 2009
    aberdeen
    2,892
    I have been outside to check everything and as ar as I can see the bushes are all good (despite being 32 years old). The rear is tight and the front tie bar ones have no movement, the control arm bushes have no movement up or down but side to side there is about 1mm but it is not free movement, to me if feels as if it is just flex in the rubber.
    The rear brake on the driver's side seemed to rub the hub slightly unevenly as the hub is spinned with one notch on the handbrake if that makes sense? ie the shoe isn't always touching. I put on new shoes today and it is the same, the hub visually looks ok.
