Have you tired fitting the 8v flywheel into the f13 housing?
Take the 1.2 flywheel off and the 2.0 8v one and put the 2.0 one on top of the 1.2 flywheel so the large center hole lines up and then turning the 2.0 one untill you get a good match with the 6 little holes im pretty sure one lines up perfect so put a flywheel bolt through to hold it there and then dremmel or drill the others till all the bolts go through and thats it perfect bodge (engineering)
