Results 1 to 5 of 5
Thread: Turbo charging 2.0 8v?
    Newbie
    May 2016
    3
    Default Turbo charging 2.0 8v?
    just wondering what spec I would have to build too,
    Any help would be appreciated
    Thankyou in advance.
    Aug 2006
    I live inside your pants
    4,527
    Start with a LET and add an 8v big block head?
    Aug 2006
    scarborough!
    2,411
    Start with the c20ne rather than the 20seh. You can use a LET multi layer head gasket, iirc its 1.7mm thick, which will obviously lower the CR a bit more. Id probably go for something like a T25 to begin with. Maybe chuck a 20seh cam in there too as its slightly wilder than the NE one.
    Im not massively clued up on the management side, and someone might say this is a bit pikey, but Im sure a bigger set of injectors and an adjustable FPR is sufficient enough on a modest build.
    Newbie
    May 2016
    3
    I already have the c20ne lying around, I've read to use the 20seh cam. The management side is what I. Really struggling with, but thanks for the comments ��
    Aug 2006
    4,527
    You will need management.
