just wondering what spec I would have to build too,
Any help would be appreciated
Thankyou in advance.
Start with a LET and add an 8v big block head?
Start with the c20ne rather than the 20seh. You can use a LET multi layer head gasket, iirc its 1.7mm thick, which will obviously lower the CR a bit more. Id probably go for something like a T25 to begin with. Maybe chuck a 20seh cam in there too as its slightly wilder than the NE one.
Im not massively clued up on the management side, and someone might say this is a bit pikey, but Im sure a bigger set of injectors and an adjustable FPR is sufficient enough on a modest build.
I already have the c20ne lying around, I've read to use the 20seh cam. The management side is what I. Really struggling with, but thanks for the comments
You will need management.
