Results 1 to 7 of 7
Thread: help braking problem on my nova
    Feb 2010
    durham
    1,529
    Default help braking problem on my nova
    Hi guys I was wondering if anybody could give me any help or pointers on a braking issue I have with my nova oval racing stockrod. Basically the brakes get a intermittent fault when now and again the pedal will hit the deck as if the there is a gap between the back of the pad and the piston, If you let off the pedal and press it again the pedal goes back to normal. I have replaced the fluid, I have tried changing the master cylinder the calipers the pads and even tried clamping the rear brakes off I did find a knackered wheel bearing and have replaced it but it's still the same. Must point out that I have tried a set of ate style calipers and the original 1.2 calipers thinking it might be the pads catching on the delco sliders.
    Any would be brilliant thanks Gareth
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    It sounds like you are boiling the fluid. This would cause air bubbles to get into the lines.
    Feb 2010
    durham
    1,529
    I have said that as well but it causes conflicting confusion because on the next corner it's fine again
    Feb 2007
    16,486
    Steam pockets rather than air.
    Feb 2010
    durham
    1,529
    Any suggestion as to rectify it would it to use some high performance fluid
    Nov 2015
    187
    As for fluid use ATE type 200.
    Feb 2010
    durham
    1,529
    Quote Originally Posted by Mxcrazy View Post
    I i have bought the ate sl6 today as its boiling point is min260c so I'll try that first thanks for your help
