Dyno meter report
max power @ wheels 122.3bhp @ 6657rpm
max power @ engine 150.8bhp @ 6853rpm
max torque 127.4 lbft @ 4985rpm
Dyno meter report
that is my plan if I have another go then I may need your help working it out, is there any chance it could have any thing to do with the way it has been set up??
Id say its more to do with not following the correct tightening procedure personally.
Dynamometer Report
max power @ wheels 122.3bhp @ 6657 rpm
max power @ engine 150.8bhp @ 6853 rpm
max torque 127.4 lbf t@ 4985rpm
well I went with what auto data recommend but there was nothing about re torqueing the head after running
do you have the settings???
Its in the haynes manual.i dont have it to hand
Working from the middle outwards:
Stage 1 - 25nm
Stage 2 - turn further through 60 degrees
Stage 3 - turn further through 60 degrees
Stage 4 - turn further through 60 degrees
run the engine up to temperature
Stage 5 - turn further through 30 degrees
The last part was an update from Vauxhall because of reported head gasket issues, its only the later manuals that mention it.
does it have an adjustable cam pulley ? ... as if the head and the deck have both been skimmed, the mechanical timing will be out if using a standard one.
also, the pistons might be contacting the gasket ? ... (if the gaskets too close a fit)
If theyre doing that then its the wrong gasket entirely
