Results 1 to 7 of 7
Thread: crank seal behind fly wheel e16se
    Feb 2015
    yorkshire
    114
    Default crank seal behind fly wheel e16se
    Just been to rolling road and had my car set up, when I got back I had a bad oil leak from the crank seal that was new.
    Now changed the seal, the new seal was a lot stiffer than the other and the oil leak has gone but there is still a small weep
    Any body had this problem????
    Feb 2007
    16,486
    Probably leaking from where the silicone goes too
    Feb 2015
    yorkshire
    114
    sorry not sure what you mean
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    a common issue if the crank is worn... or you're just unlucky with cack seals... get a genuine GM one.
    Feb 2007
    16,486
    Quote Originally Posted by jamesbray View Post
    Then thats probably why...
    Where the crank seal goes at the last cap your supposed to inject rtv silicone down the sides of the cap as per the build manual.
    Feb 2015
    yorkshire
    114
    I have done this your there is a reses on each side of the cap, 2 b honest I put silicone in the groves then bolted the cap up to the crank.
    Feb 2007
    16,486
    Could be that.
