Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 85
Thread: Xe nova
  1. #21
    Feb 2012
    Lurgan, ni
    110
    Went out to the garage for an hour to check clearances
    Hose is touching the slam panel
    This is the radiator moved behind the mounting point and it's still tight so I'll have to drill a new mounting point hole. Think I'm gonna cut the slam panel off and weld brackets on to it for ease of access to the radiator and the manifold
  2. #22
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Get your hands on a genuine exhaust manifold (pref a stainless one) ands you'll probably find you'll have more room...
  3. #23
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    Ashley 4-2-1? Mine has a fair amount of room and did on the standard bottom mounts too. Either its made slightly differently to mine or your engine sits a bit further forward?
  4. #24
    Feb 2012
    Lurgan, ni
    110
    Yeah it's an ashley one, I remember a friends being very close to the radiator, it may be my offside mount I made but none of the mounts look twisted tho.
  5. #25
    Apr 2003
    South Wales
    6,566
    Ah Ok - It looks the same diameter as a standard on in the pics?
  6. #26
    Feb 2012
    Lurgan, ni
    110
    It's a similar design will just a larger bore all round, your comment makes sense now
  7. #27
    Feb 2012
    Lurgan, ni
    110
    Got a bit of time spent on the nova over the past couple of days, got the engine running then took it back out again to cut what needed cut.
    Few pics of the alternator notch
    Tidied it up a bit
    Have to finish welding in the strengthing plates in now and then start to prep the bay for paint
  8. #28
    Feb 2012
    Lurgan, ni
    110
    Got the strengthening plates all welded in the front,
    Next step is to pull the dash out so I can stitch the legs and bulk head then I can finally start on the engine
  9. #29
    Feb 2012
    Lurgan, ni
    110
    Currently finishing the bay trying to get it in primer, lots still to do tho
  10. #30
    Feb 2012
    Lurgan, ni
    110
    Current situation
    hope to have its finished in July sometime
