Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Spot weld removal :(
    User Danb1987's Avatar
    Aug 2010
    Chesterfield
    1,215
    Default Spot weld removal :(
    Evening all,
    Are the little spot weld bast@rds as hard to get out as im making them look.
    Only tried a few so far and already manage to put a hole in my rear 1/4.
    Any tips etc.
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    You must be making hard for yourself
    http://www.pngclub.com/forum/showthr...ngs&highlight=
    success is only limited by a weak mind
    May 2013
    norfolk
    333
    Buy a good quality spot drill bit I got a couple of dormer. I've just removed both quarters, rear panel, sills an other bits an just started on my second bit. I found a battery drill ideal a bit of wd40 ( for lubrication ) an go medium speed. Don't push to hard or you'll blunt the bit quick as, basically nice an steady let the drill do the work
    cheers Rich
    Aug 2010
    Chesterfield
    1,215
    Iv got 2 types of bit. A cutter type one and a traditional style one. The cutter just jumps around even though iv drilled pilot divets.
    Aug 2010
    Chesterfield
    1,215
    Looking at that article it seems theres little way of stopping the drill sometimes going though both panels.
    I guess itl just take a bit more time with the welder.
    May 2013
    norfolk
    333
    If it's like the one I brought from machine mart bin it there crap. Stick with a standard one an pay a bit more it's a good investment while you own a nova . Once you've a done a few you'll get the hang of it. When you think you're nearly through stop get a thin flat blade an slide it between the panels an give it wiggle then you'll see if you need to go some more
    Rich
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Going thought is totally normal. Dont worry about it.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    May 2009
    renfrewshire
    10,167
    Quote Originally Posted by Danb1987 View Post
    it takes a bit of experience to feel when you have only went through one panel,
    as said earlier the Dormer ones are great and what I use too,
    Jul 2008
    Unknown
    9,635
    Drill until you see rust that means you reached level 2 I must of drilled close to 300 on my van
  10. #10
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    You want the 8mm 'regular' looking drill bit with a slightly flatter head
    If you can pry the panel a little bit you'll feel when you're through the top layer as it'll ping slightly, but rust is a good indication.
    If in doubt, stop early and continue with the others, then pry and drill the final bits one by one as necessary.
    Thin metal to thin metal is easy (1mm on 1mm) but thicker stuff like seat brackets are a pain.
