Page 10 of 30 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 300
Thread: Mk2 Breeze Blue project
  1. #91
    Club Member Club Member
    Jul 2008
    Greenhithe
    1,614
  2. #92
    Jul 2008
    Greenhithe
    1,614
    So found some more time recently to crack on with this. Really need to get a move on so it can see the road next summer.
    So started putting some bits back on this now and got the first coat of paint underneath. Also done a few coats on the inside floor as I was sick at looking at it!
    I have new front bearings to be fitted to the front and then they can go back on with the tie bars and new bushes for the bottom arms so they can be refitted. I tried pressing them in myself and it broke the vice so will be taking them to the garage to fit.
  3. #93
    23,813
    All good jobs.
  4. #94
    Jul 2008
    Greenhithe
    1,614
    Refitted the sound proofing which is in ok condition, just a little ripped around the accelerator pedal.
    I've cleaned up the heater box so that can be reattached tomorrow but will dig out the speedo cable first as I always remembered that being a arse of a job to get that through the hole when the dash was in. Also the knuckles have been collected with new bearings fitted and the bottom arms have new bushes so again can refit tomorrow if time permits.
  5. #95
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    Ahh so the refitting has begun! The best and most satisfying part!
  6. #96
    Jul 2008
    Greenhithe
    1,614
    Does fill good to put it back together. It's just the inner arches and rear floor to finish but they are in far far better condition than the rest was. Just a few welds, a rub down, then under seal and paint. Hopefully the dirty bits will be completed by the end of January whilst still re fitting stuff and starting on the engine.
  7. #97
    Jul 2008
    Greenhithe
    1,614
    So most of the front running gear is put back together now, may even drop it on wheels so I can paint where the front axle stands have been for the last year and half. I am having trouble with the passenger ball joint being pressed into the knuckle so borrowing a c clamp to hopefully sort that.
  8. #98
    Jul 2008
    Greenhithe
    1,614
    Also fitted the rad fan I had but it is the smaller option and the radiator is a larger one. It's fine and doesn't move but may need to find a larger one once it's running
    Have also completed the main underside painting so just leaves the back end to finish. The sound deadening has been removed from the spare wheel well so just needs tidying and I'm in the process of refitting the engine loom to the car.
    Talking engine I have shifted the garage around and made up the engine stand so I can crack on with that between jobs this Dec/Jan.
  9. #99
    Apr 2003
    South Wales
    6,566
    You're flying now mate! What engine' going in? I cant remember!
  10. #100
    Jul 2008
    Greenhithe
    1,614
    14nv bottom/ 13sb top with Weber 32/34 dmtl.
