Has anyone any pics or advice. I need to do some welding around engine bay seams and especially just behind the passenger side front strut tower. I'll try put up some pics of my own and show the condition.
cheers
cheers
Usually accessible from under the arch.
That's not mine, but this is the area I mean. I'll try get some pics over weekend.
Cheers
You can access that area from the wheel arch, engine bay and inside of the car easily if the dash and wiring harness is out.
1.6 16v's are the way forward!
Difficult takes a day - impossible takes a week!
Go in from the top. Cut out what you can, clean it up and weld back in.
Take your bonnet off to make life easier. Quite a common seam to rot out..
It's a stripped out shell and gaining access is not a problem. It's more I'd just like to see examples of others that have carried out this
Some pics in here
http://www.pngclub.com/forum/showthr...ck-Build/page4
success is only limited by a weak mind
90% of people just wap on a plate from underneath or the top and think that's it sorted, the issue is that this point is where three panels meet, water gets into this area and rots from the inside out, so you have two options
botch it up
or
fix it right
Here's what we did in this area.
http://www.pngclub.com/forum/showthr...re-build/page4
Cut it out from inside the wheel arch and then touched it up from inside the car aswell.
