Am I going mad here or does none of this work with eachother?
Problem 1: Reservoir fittings, threads right but they both look like convex to me
Problem 2: Master cylinder pushrod length. It's too long, if I cut it down it'll be right at the end of the threaded section, is that OK for adjustability? Pic shows it wound all the way in and how much I'd need to remove.
Problem 3: For some reason the M10 thread coming out the bottom is a good 7cm+ shorter than the standard one, what am I supposed to do here, bodge it up with threaded sleeve and extra rod until it reaches the pedal?
