Results 1 to 10 of 10
Thread: hub and brake question
    Apr 2011
    N.ireland
    216
    Default hub and brake question
    hey, I was just wondering would conversion hubs from a corsa b fit a nova? as I have a full redtop corsa here that im using for the engine for my nova, and would be very handy if I could use the hubs and big brake setup off the corsa.
    cheers
    Apr 2012
    North east
    485
    I believe the front hubs and brakes will fit although if I'm wrong I'm sure someone will correct me and that I'll be looking for another set of hubs for mine!
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    I'm pretty sure they have different bearing sizes, but I though all the geometry differences were in the bottom arm and balljoint and not on the hub.
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    I could be wrong but I'm sure the corsa hubs are 2mm bigger than a nova.
    Sep 2004
    East Midlands
    13,604
    Waaaaiiiiit a second are we talking about hubs or knuckles?
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    I've used Corsa hubs on a nova before and it tracked up OK. As long as you use both corsa and not one of each, as they are slightly different!
    Apr 2011
    N.ireland
    216
    see iv broke a redtop corsa to use the engine for my nova and was hoping I could just set the hubs brakes and drives all into my nova from the corsa, would save me a lot of money if I could use these,
    Apr 2006
    aberdeenshire
    1,348
    Quote Originally Posted by -fred- View Post
    Yes that will work however you will need to use nova shafts. corsa shafts are longer.
    Apr 2011
    N.ireland
    216
    Iv gte nova shafts here would they be ok?
  10. #10
    Aug 2006
    I live inside your pants
    4,527
    the hub flanges are the same so why not just swap the callipers and the discs? save the confusion with shafts and use your nova hubs.
    if its rears, they will bolt straight on.
