Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: New member from Belgium
  1. #11
    23,813
    I think any bracing helps movement/flex
  2. #12
    Dec 2015
    8
    Can't help to thinck this is stronger than adding some plates to the pickup point .
    As I see it this should help mutch more and simple to install.
  3. #13
    Jun 2013
    Cleveland
    436
    You going for a off he shelve cage or a custom fabricated one? If you gonna have one made/make your own I'd highly recommend a bar across the rear arches and also bringing the cage through the bulk head to the shock turrets. There is next to no flex in my shell, it's literally tighter than a gnats chuff .
  4. #14
    Dec 2015
    8
    I've bought a OMP cage fia approuved, I can't alter it and bring it to the front turrets.
    Anyway we run most of the time on public roads for the hillclimbs and not all of them are
    nice and flat, therefor to stiff is no good. Sepperate from the cage I can install a cross
    between the rear shocks
  5. #15
    13,604
    Looks like you know what you're doing, shell prep looks good, I can't see that bracing hurting anything.
    I too would recommend triangulated front-end, is it not possible to get an FIA cage with this built in?
  6. #16
    Dec 2015
    8
    Does anybody change anything on the wheel carriers, steering akkerman arm.
    I know about the bigger bearings
  7. #17
    13,604
    Some people invert the taper on the steering arm to run it upside down, or change to a rosejoint and bolt. But have mixed succeed in doing these mods so my word of warning would be to make it reversible.
