Results 1 to 7 of 7
Thread: xe flywheel bolts
    Oct 2011
    falkirk
    172
    Default xe flywheel bolts
    I've bought an xe with gearbox yesterday with apparent goosed bottom end. Got it home and stripped gearbox off - only for flywheel and clutch to fall off with it. It's sheared 7 bolts in end of crank (one missing I think - still to check sump). Has anyone came across this before and any idea what might cause it? Only thing I can think of is the bolts have been stretched, reused and snapped under strain. Any help appreciated.
    Feb 2007
    16,486
    Iv always reused flywheel bolts.my race car has done over 20meetings over two seasons on the same bolts it had prior to me rebuilding it.
    cause-something jamming up in the gearbox or diff at very high rpm id say.either that or you have been a monster removing the box
    Oct 2011
    falkirk
    172
    I'm a gentle giant .
    Both gearbox and engine turning fine. Never had/seen this before. Other theory was they've never been tightened fully.
    Feb 2007
    16,486
    Thats possible but would more than likely go through the bellhousing and anything else in the way.The results are catastrophic when a flywheel lets go
    Senior User Club Member
    Apr 2003
    South Wales
    6,566
    If a few of the bolts weren't tightened properly and came loose, it will shear the rest off
    Oct 2011
    falkirk
    172
    The boy said it was on over run when it happened. Didn't look fully shilling tbh . Can only try drill them out and refit new ones and go from there
    Apr 2012
    North east
    485
    Don't drill them out, weld a nut on the end and just turn them out like a bolt. Much easier, quicker, safer and cleaner way of removing snapped/sheared bolts.
