Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Now you can check easily your car - MOT HISTORY
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Default Now you can check easily your car - MOT HISTORY
    The DVLA have updated there website for checking your cars MOT history, easier now:
    https://www.check-mot.service.gov.uk
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Quite interesting to rear when you have a fail... I didn't remember all this.. But i remember them being so picking and harsh over everything...
    • Reason(s) for failure
      Nearside Rear position lamp(s) excessively deteriorated so that it is not visible from a reasonable distance (1.1.A.3d)
      Offside Rear position lamp(s) excessively deteriorated so that it is not visible from a reasonable distance (1.1.A.3d)
      Offside Rear fog lamp not working (1.3.2b)
      Nearside Stop lamp not working (1.2.1b)
      Offside Stop lamp not working (1.2.1b)
      Nearside Front Direction indicator excessively damaged so that it is not visible from a reasonable distance (1.4.A.2e)
      Nearside Front Direction indicator incorrect colour (1.4.A.2f)
      Nearside Side repeater not working (1.4.A.2c)
    • Advisory notice item(s)
      front bumper and grille missing.
      battery insecure.
      screen washer reservoir insecure.
      offside front chassis member damaged.
      spare wheel well has been removed and quality and strength of repair unable to be properly assessed due to paint and underseal.
      car has had extensive welding repairs to offside and nearside front inner wings/chassis.
      offside and nearside front tyre treads low on inner edges.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
    Club Member Club Member Nova00's Avatar
    Jun 2009
    Manchester
    984
    Rather a long list of failures over recent years !
    Quote Originally Posted by Southie View Post
    https://mot-history.net
    Nova SR 1.4
    User raf24's Avatar
    Jul 2010
    ayrshire
    1,478
      Registration plate lamp not working (1.1.5c)
      Offside Headlamp insecure (1.7.3)
      Front Suspension component mounting prescribed area is inadequately repaired (2.4.A.3)
      Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Nearside Outer Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Offside Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Nearside Front Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
      Offside Front Suspension spring mounting prescribed area is excessively corroded (2.4.A.3)
      Nearside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
      Offside Front Suspension arm has excessive play in a ball joint (2.4.G.2)
      Nearside Front Brake hose excessively deteriorated (3.6.B.4d)
      Offside Front Brake hose excessively deteriorated (3.6.B.4d)
      that was the last mot before i got my gte,total rotbox
    User Club Member rubachuk's Avatar
    Apr 2008
    Rochdale
    537
    Better than the old system because you don't need the last MOT cert no or V5 no.
    I used the old system to check out a couple of Galaxys I went to look at 3 or 4 years ago, both supposedly with 80K on the clock. MOT history told me only a few days before I viewed them that one had 230K and the other 186K on the clock. Both MOT'd at the same garage.
    Neither police nor VOSA seem to give a toss.
    Senior User raymond's Avatar
    Feb 2005
    blackburn
    2,745
    Quote Originally Posted by raf24 View Post
    It was probably bent tested when I had it so that would not have done it any favours to be honest
    Senior User Mike's Avatar
    Mar 2004
    26,594
    That's mega my old Corsa C van is still going strong with 179k miles in August this year
    Jul 2013
    Liphook
    415
    Wish this was available before I bought the last one to find it had all the rot in the world covered up by filler and expanding foam! Annoying that the MOTs that came with the service history had nothing on them - I was had It has been rusting for years according to the DVLA!!! Most are failures and the passes are a day or two after with no advisories - someone had a friend in the trade!
    Test date 9 March 2015 Test Result Fail
    Odometer reading 46,130 miles
    MOT test number 7351 0806 5027
    Electrical wiring insecure (1.9.2a)
    Horn not working (1.6.2a)
    Hazard warning switch faulty (1.4.B.1d)
    Hazard warning lamps inoperative (1.4.B.1b)
    Registration plate lamp not working (1.1.C.1d)
    Nearside Headlamp aim too high (1.8)
    Offside Headlamp aim too high (1.8)
    Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Nearside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Nearside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Nearside Front Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Front Macpherson strut has excessive movement at the upper attachment (2.5.A.1c)
    Nearside Rear Body has a sharp edge caused by corrosion (6.1.C.1)
    Nearside Rear Mechanical brake component has restricted free movement (3.5.1k)
    Service brake: efficiency below requirements (3.7.B.7)
    Offside Rear wheel bearing has slight play (2.6.2)
    Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
    Parking brake: parking brake efficiency only just met. It would appear that the braking system requires adjustment or repair. (3.7.B.7)
    Oil leak
    vehicle very corroded marked areas with yellow chalk
    Test date 5 October 2013
    Test Result Fail
    MOT test number 7589 9857 3274
    Centre Registration plate lamp not working (1.1.C.1d)
    Test date 2 March 2011
    Expiry date 14 March 2012
    Test Result Pass
    MOT test number 3169 0196 1035
    Nearside Rear Suspension spring mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    Nearside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    n/s/f and o/s/f inner wings corroded
    front slam panel corroded
    rear axle corroded
    n/s and o/s inner sills corroded
    n/s and o/s outer sills corroded
    o/s inner sill covered with uderseal and unable to fully assess
    n/s f and o/s/f outrigger corroded
    oil leak engine area
    n/s/f and o's/f wheel arches corroded
    front crossmember corroded
    n/s/f and o/s/f chassis corroded
    Test date 28 February 2011
    Test Result Fail
    MOT test number 9694 0925 1036
    Nearside Front constant velocity joint gaiter split (2.5.C.1a)
    rear axle corroded
    Test date 8 March 2010
    Test Result Fail
    MOT test number 5843 7786 0093
    Offside Headlamp not in good working order but not adversely affecting beam image (1.2.4a)
    Nearside Front wheel bearing has slight play (2.5.A.3c)
    Test date 11 March 2008
    Test Result Fail
    MOT test number 1044 6107 8052
    Nearside Front Upper Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Front Upper Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Rear Suspension component mounting prescribed area is corroded but not considered excessive (2.4.A.3)
    corrosion on front slam panel
    Test date 14 March 2006
    Test Result Fail
    MOT test number 2837 6387 6075
    Club Member Club Member DaveMarshall's Avatar
    Jul 2004
    Swindon
    525
    Great find, massive help now you don't have to provide a V5 reference number. Helps me as I get a lot of burnt out cars in at work for breaking, before as I had no V5 I couldn't get the last known mileage to help sell parts but now it's nice and easy.
    Dave.
  10. #10
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Quote Originally Posted by DaveMarshall View Post
    Dave.
    Glad to help out
