My c16se build im so worried about valves hitting piston with a 285 cam,i think my head has been skimmed a lot but dont know how to tell?any one ever machined top of pistons?
I'm not sure but with a cam that has over 12mm of lift it will be close,if I do the blue tach test or if it does touch on a dry build test I should be ok taking some off piston crowns,I have a good frien with a laith
Is it 12 mm lift at TDC?
i will have to check once I start putting together I was just presuming that if the cam is 12mm lift it would be at tdc?
Is your head on?
If not take a pic of the face.ya can take loads off em on a skim.
No head is off its at machine shop at mo but will get some pics when back,will it say on cam details what tdc lift is?
It's piper 285
Your best bet is to try and find some really weak springs to fit instead of the std gm valve springs, then try a dry build with one piston (without rings would be better) using the old head gasket nipped up. A really good waycto measure the ckearances is to use some solder twisted to look like a spring & sat on the piston top. (This is how lister industrial engines check clearances) then turn it over twice to make sure.
