Size is for the spare plugs in the block. I think the oe place in the back of the pump is a smaller size. In fact may be the right size?
The 1/8 sender was too small.its going in the pump at the back.
OK ignore my m14 comment then as not 100%
this means il have to get oily now
Found one in my box of grassing spares.il fit it this week.No shop in this foresaken shithoyle had any
if you end up selling the sender then give me a shout
So the oil pressure light will earth via the sender unit when the engine is running and there is oil pressure? How does the light work then, how does the car losing pressure and the sender not earthing anymore activate the light?
I am looking to wire in an electric fuel pump in an early carb car and wanted to use the oil pressure sender in the wiring as a safety measure. Was thinking of earthing the relay via the sender unit.
Will also use an inertia switch.
