Another new month, another update...
Finished the Ryemoor rally last month in the black Astra. Good finishing position but had been bad fog and we lost time due to my lack of confidence..
Then spent some time cracking on with the "gravel car".
Back in the workshop, and on stands
Updated the To-Do list for the car on the board..
I already had one fuel line for the carb system installed so decided to use that as the return line and bought a stack of fuel line bits / pumps to properly fit the feed line.
The new feed system will run from the tank outlet (at the rear of the tank) in AN8 size, through a fuel filter and into the twin pump setup in the spare wheel well. It then feeds back into a single AN6 fuel line, around the outside of the tank (so its protected by the tank guard) and up the passenger side of the tunnel next to the return line. Cracked on with making up the lines..
and fitted the fuel pumps in their spare wheel well location. Now waiting on the Vauxhall specific angled fuel tank outlet pipe to make up the rest.
Also temp fitted my new seats into this car,. They mount wider than the older ones so will need a bit of tweaking. I had to get this done before starting to make the gearlever bracketry..
and then used an old mount (from the other car) as the basis for the cable shift lever mount. This puts the lever much higher in the car. Going to copy the system used in the tarmac car for this as it was excellent at Donington.
I was also offered a new project a few months back....
Its a nice straight, rot free 3 door shell thats been partially converted for trackdays.. However, the cage isnt to MSA spec and theres a few oddities added on it. Ive decided to build a decent spec road-rally legal and fast road car with it.
It needs to have standard inlet on the car to comply with roadrally rules but will have a slightly tweaked engine, hybrid gearbox with low final drive and long 5th gear, decent LSD, MSA legal cage and seam welded / strengthened shell and decent spec suspension. To that end Ive sold the black car (hopefully picked up this weekend) and this will be the next project in line after the gravel car is done and the tarmac car has had a few little niggles sorted.
Paul..
