Or x18xe1/z18xe on bike carbs, I know this is a Corsa,but you'll have more bulkhead room in a Nova.
https://m.youtube.com/watch?v=5LdwkSYBbKA
Imo what you loose in the corners with a big engine you more than make up for down the straights. Would love to be joined out on track by a small block and be proved wrong though.
On my budget the most powerful engine i could afford to fit was the V6.
Let if you like constantly having problems
xe on carbs for feck all to go wrong running
told you saloons are the future!!!!!!!
Not had a single engine issue with my let in the 3yrs I've owned it and it sees 22psi frequently . Only slight problem was the cts code 15 which turned out to be a corroded loom plug, even for the couple of times I drove it till I found the problem still ran and boosted fine. Compared to some of the engine's I've had over the years the let seems like a master piece in terms of reliability lmao.
Something will oil pishing out from the sump (stops the rot)
Well Blue peg, about that...
Everybody on here thinks the Courteney conversions did
