Updated 12/01/16
Clearing out the garage and realised I'd not chucked the remains of all this away yet
Last call if anyone wants anything, most of this will be going in the bin otherwise. See pics below for the most stuff, there's also a few other bits not pictured which I think I still have floating around somewhere. Prices all negotiable, most stuff can be posted for extra cost.
From the top...
Velour headrests, just out of shot. Can get a better pic if wanted. £10
New/unused RAC parking sensor, fits behind bumper so no holes required. £20
Cav scorpion exhaust, needs a hanger welding on or just use a universal strap £10
Cav rear electric windows (boxed up in the pic!) with loom and runners £10
Astra Mk1 arch extensions, 3x rf and 1x lf. Ideal for cutting up and fitting to saloon arches £10
Cav mk3 wing mirror switch £5
Nova Mk2 centre vent cowling, clock bit cut for different clock £10 for all three pieces together (i.e. dial and headlight bits below)
Infinity tweeters mounted in Mk2 dash speaker grills £10
Opel gearknob £20
Nova expansion bottle
Rear quarter ashtray
Mk2 dial cowling, uncut
Cav clock, x3 £5 for all of them
Spax RSX adjuster
Opel badges:
- big one is 5" across with a 4" circle and angled to fit a bonnet (Monza?)
- smaller one is 2.5" x 2.25" and flat
- black/chrome one is possibly from a Manta A or something?
Plastic thing that goes under the scuttle panel between that and the heater cover
Cav headlight levelling motor
Front seat belt clips
[strike]Rear bumper light[strike]
Pair of Cav track rod ends
[strike]Interior lights[strike]
Mk2 headlight clips (6 I think) £5
Air mass sensor, pn 0 280 212 015 (fits a C20XE engine I think)
Mk1 fuse box cover £2
Fuse box with wire and relays £5
Mk2 headlight cowl, uncut
Saloon boot lock with all bolts, mechanism and key £SOLD
Oil filter, pn 93156300 so should fit pretty much anything
Mk2 GSi electric window switch housing £5
Omega(?) interior light
Another boot light
Centre bush for a rear ARB £5
Door check straps from a 2/3dr, not sure why I have 3 of them £5
Nova tow bar, with bolts and hitch £10
Saloon plastic rear trim £SOLD
Vectra washer jets and hose £SOLD
Autogauges oil pressure sensor, 52mm iirc £SOLD
Nova electric wing mirrors, need putting back together but the motors are fitted into the housing. Untested as I don't have the means to test them and don't want to cut the plug off the motors in case someone wants them intact. Comes with Cav Mk2 switch and heated pads if you want to fit them behind the mirrors too. £SOLD
Also...
Cav Mk3 Haynes Manual (88 - 95)
Vauxhall/OPel Diesel engine Haynes (82 - 96)
Better pic of the gear knob
Wing mirrors
Tow bar
Parking sensor kit
Tweeters
Astra GTE arches
Saloon rear panel
