Is it possible to to buy a standard GTE/GSi 200mm clutch cover from Vauxhall? I'm using a Helix plate so don't need that.
Also, any idea on, price?
be careful using standard pressure plate, with having lesser clamping force it could wear down the friction plate easier
iv just had a load of bother with mine for the 2nd time and iv put it down to 2 possible reasons, billet steel ttv flywheel getting too hot killing helix 4 paddle clutches (twice) or stock pressure plate not clamping hard enough, causing it to slip and heat up the fly too much. ended up splashing out on full kit and stock flywheel skimmed/balanced
