Results 1 to 10 of 10
Thread: Question about bushes
    Mar 2015
    170
    Default Question about bushes
    I'm restoring a 1.2 merit and plan on fitting a c20xe, will I need to upgrade my bushes to polybushes? I will be running a set of coilovers if that makes any difference to the answer, engine bay will also be stich welded
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    What bushes, suspention or engine
    suspention - it wouldn't hurt as gone rubber bushes are 20+ years old so gonna have some play
    poly sport ones are a happy medium as there not so stiff that you break your teeth
    engine - just fill the gaps on the drivers engine mount with tiger seal to stop most of the movement
    Mar 2015
    170
    Suspension bushes, I have the complete front end stripped engine out and all so I'm going to replace the arm and ball joints, mounts for steering rack seem ok how important would poly be for the steering rack? Also the new arms come with new bush's would be a shame to have to replace them for poly but if you think I need to I will, only other bush's I can think for are tie bars, as for the engine I will be buying a mount kit but I will fill any gaps as you say
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    It would hurt to replace the other bushs, rack ones would be a lot Easyer etc while engine is out but not necessary
    Mar 2015
    170
    Will the arms be ok with standard bushes? They are brand new,
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    Yep, but polys arnt expensive if u want a less play
    User chris gsi's Avatar
    Sep 2005
    gloucester
    1,284
    I use the bushes from rally designs,I had the poly race ones in my old track car and have just fitted the poly sport ones to my current nova.
    Mar 2015
    170
    Much difference in comfort between poly and standard? I plan on driving my nova on the roads at weekends etc I won't be rallying or anything like that, but at the same time I don't want to be changing worn standard bushes out every 6 months because that arnt up to the task of a c20xe
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    Standard new bushes will probably be fine. Usually cheaper and easier to replace with poly and they tighten it up a bit.
  10. #10
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    new rubber ones will be fine imho.
    Plenty of supercars running rubber bushes
