Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Drive shaft removal query -
    Newbie Club Member
    Jan 2015
    Monyash
    40
    Default Drive shaft removal query -
    A couple of quick q's chaps:
    1/ Drive shaft removal - I'm looking to remove both driveshafts from my '89 SR. Haynes manual mentions a special tool to release from the transmission (which I don't have) or using a large screwdriver to release the circle. At the moment I have fairly limited access so the question is how much effort is required to release this circle ?
    2/ Engine & box removal - If the above goes to plan, am I right in saying that without the shafts the engine together with 'box will come easily from above ?
    Cheers
    Paul
    Feb 2014
    Selby
    996
    I just gave mine a short hard tug and they both came out easy mate
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    You can use them as a slide hammer to pull them from the box, probably not ideal for the inner CV but works
    It's easier going out the bottom still (e.g. can do it purely with jacks although a crane is easier) but I'm sure Benn will come here crying about how everyone who removes an engine from the bottom is a pansy and should be slapped
    Newbie Club Member
    Jan 2015
    Monyash
    40
    Thanks for the prompt replies - top job !
    ^^ Looks like there's not too much effort required then . . . .
    ^ I'm lucky enough to have a pulley chain block hanging off an RSJ, so it's coming out from above
    Sep 2004
    East Midlands
    13,604
    If you remove it from above and plan to push the car backwards out the way, put a spare outer CV in the hubs and tighten up to keep the wheel bearing tight.
    Moderator Moderator conza123's Avatar
    Dec 2011
    Sandwich kent
    2,339
    2 Post(s)
    I tried levering mine out with no success so got the hump and gave them a hard tug and they came out
    Club Member Club Member Royston's Avatar
    Oct 2007
    Near Darlington
    3,549
    As said, use the driveshaft as a slide hammer, ideally the outer is removed from the hb, or the lower ball joint disconnected.
    Close the driveshaft up, i.e. push it all the way in the yank it out, the inner circlip should just pop out.
    Hope it makes sense!
    Regards
    Royston
    Club Member Club Member Jonesfach's Avatar
    Feb 2014
    Wrexham
    573
    I have changed one on an 89 SR. without the special tool.....big screwdriver job.
    i found the bearing in the front wheel the hardest part. Was damm tight had to get some scaffold pole out for leverage to undo it.
    Feb 2007
    16,486
    Whats wrong with a prybar between box and cv cup?
    Or a cold chisel between the two and a tap with hammer.
    its never failed the thousands of times for me.
  10. #10
    Jan 2004
    Hertford
    2,069
    If all fails drop the diff plate and prize out off the diff housing.
