Finally got to the stage to start my car and it won't start.
The story is its a c20let conversion in a mk1 1.2 shell, if it makes any difference. I have followed the wiring guide in the article section and the fault I'm getting is no spark and no injector feed. I have been through the loom and have checked the 12v feeds to the ecu, the switched feed and checked the earths and all seem good. I have fitted a new coil and fitted a good crank sensor and still no joy. I have an ebay fuel pump relay fitted and the pump just runs when the ingition is turned on-I'm sure it's ment to prime and then run when the engine is running. Would a dodgy relay cause the fault, of it not starting?
thanks chris
