Hi all
Is there a way to run a speedo cable and digi dash sender from the gear box at the same time? I understand that you can only have one plug on the gearbox obviously, but wondered if there was a way to effectively use both?
In my head I visualise being able to split the digi dash sender, remove the spigot and reseal sender around speedo cable etc - obviously not as straight forward as that but you get what I mean....having not seen inside the digi sender yet I don't know where the contacts sit to create the signal etc.
Cheers
Steve
