Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Is there a way ?
    Senior User phunkynova's Avatar
    Feb 2010
    Neuburg a.d. Donau. Bavaria D.E.
    1,571
    Question Is there a way ?
    I was sent a new Piper Camshaft for my 1.4 8v BUT someone had installed the 8mm steel ball bearing in the dizzy end of the camshaft is there a way to get it out without damaging the cam (new camshaft is in the post to me)
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    only way I can think of is to put a 4-5mm hole in it and use a stud extractor
    Feb 2010
    1,571
    Harden Steel ball bearing will be hard to drill and then screw anything into it, Stuart.
    Nov 1999
    35,414
    18 Post(s)
    weld something to it?
    Feb 2010
    1,571
    It will need some dam good precision welding at only 8mm at its widest point.
    I all so play with the idea of grinding it or trying to glue some thing to it and pull it out.
    Aug 2006
    I live inside your pants
    4,527
    If the only reason you want it out is for fitting the distributor, just grind 5-6mm off the distributor drive pin as you dont need it now anyway.
    Feb 2010
    1,571
    I would prefer not to grind a part of my brand new motorsports dizzy
    Aug 2006
    4,527
    Why not? Stick it in the lathe and machine it tidy. The ball is only there for dispack engines anyway as the o-ring on the drive would normally block the cam. Chances are anyone who wants a motorsport distributor will have a plugged cam anyway. Its not like the drive cant be pressed off and replaced in the future...
    Apr 2006
    aberdeenshire
    1,348
    Quote Originally Posted by phunkynova View Post
    Grind an old one then swap the drives over. You just tap out the roll pin and it comes off. Some dizzys don't fit without a bit of fettling anyway.
  10. #10
    Feb 2010
    1,571
    Just not keen to mess with the new dizzy as it is under warranty
