As most of you will know, I have a strange fascination with e16se engines.
The ignition and injection timing are controlled by a single hall effect sensor inside the dizzy.
My question is: is fuel injector timing actually that critical? The reason I ask is that this engine originally ran on 4star leaded, and to run on unleaded, it needs the timing retarded.
Would it be worth putting a second sensor on for fuel timing?
