Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Plumbed in extinguisher
    Senior User Iain's Avatar
    Sep 2004
    East Midlands
    13,604
    Default Plumbed in extinguisher
    Anyone fitted a plumbed in fire extinguisher? Wondered if anyone had done the hard work finding the ideal location and cable/pipe routing!
    Pics please for inspiration!
    Sep 2004
    East Midlands
    13,604
    Thinking of this position. Am I right in thinking the cables run from the handle down the tank? So I can run the cables down the will and up to the scuttle?
    Club Member turbojolt's Avatar
    Jan 2007
    derbyshire, derby, shelton lock
    10,358
    Why not route it through the same holes as your washer fluid uses?
    ^^^ did you just read that? what a idiot ^^^
    PROJECT 2 FAST 2 FAT clicky
    ''lifes what happens, while your busy making plans''
    Sep 2004
    East Midlands
    13,604
    Was thinking of around there if not the same hole. Just figured someone would have some 'been there done that' kind of tips!
    Apr 2011
    wiltshire
    1,938
    Sep 2004
    East Midlands
    13,604
    Sweet pretty much what I had in my head. Thanks
    Apr 2011
    wiltshire
    1,938
    And yes, top jaw comes down. I used 6mm P clips from Maplin which dont grip the cord too tight, and enlarged the old sill protector screw holes down the N/S for pop rivets.
    Get a 12ft cable for the outer pull, then shorten it and if you want to be posh like me use a stainless cable end from a bike shop.
    Sep 2004
    East Midlands
    13,604
    Got 2 what I assume are 6ft cables with the lifeline kit so hoping it'll be long enough go reach the scuttle
    Apr 2011
    wiltshire
    1,938
    My black internal cord is 6ft, won't be long enough for the exterior.
    Edit, maybe, yours will be, it's 1ft to the left of mine...
  10. #10
    Sep 2004
    East Midlands
    13,604
    Balls.
