Nice Job
Cheers.bit stuck can someone help my front panal lines up wings fit fine bonnet etc but the front Pannal don't touch the chassis leg ether side on the outer edge but the welded side Ok so is round the head lights is this normal?? :/
. . . I'm glad you've brought this up, as I thought it was just my (shoddily) built SR - but maybe they're all like this !
I have the front end off mine at the mo, but with the front panel still attached - It's exactly the same in that there is up to a 5mm gap between the front panel from top to bottom on the outer edge.
I'm no expert, but mine is certainly all original - hope it helps ?
They are all abit + or - a few mm. All over.
Good stuff that has helped alot was thinking more work cheers better get it welded on then
Front Pannal all welded on now started pass side inerwing to find this thought the other side was bad!!!
