Results 1 to 8 of 8
Thread: Are 16xe and 16se clutches the same.
    Apr 2006
    aberdeenshire
    1,348
    Default Are 16xe and 16se clutches the same.
    Is their a difference between the 16se and 16xe clutch. Could you fit a nova clutch for a e16se flywheel onto a corsa x16xe flywheel. Or are they different since one is flat type and other is pot type flywheel.
    Club Member Club Member comptoncj's Avatar
    Jun 2007
    Biggleswade Builds: Flame red GSI
    1,828
    I believe they are different due to the flywheel differences the pressure plate on a 16xe sort of sits inside the pot type flywheel. However it's probably a good idea to put a flat one on as the pot type are heavier.
    H27 ODW nova GSI
    B333XYP nova hutchinsons cabriolet
    Apr 2006
    aberdeenshire
    1,348
    thanks. problem is i have bought a billet fly wheel and not sure if its a billet 16v or billet 8v one. its now flat so i take it the 8v one is the only one that will fit.
    Jun 2007
    1,828
    If it's flat then it's an 8v one if it has steps in it where the bolt holes are it's a 16v
    H27 ODW nova GSI
    Mar 2010
    Newcastle
    3,276
    8v is flat flywheel, 16v is pot flywheel. Pressure plates are different.
    Apr 2006
    aberdeenshire
    1,348
    so is this for a flat or pot type clutch?
    Mar 2010
    Newcastle
    3,276
    flat
    Apr 2006
    aberdeenshire
    1,348
    Quote Originally Posted by Mieran View Post
    flat
    great thanks.
