Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: handling problems
    Oct 2007
    Charlesworth Glossop
    260
    Default handling problems
    Hi all
    I have a K ref nova and it handles like a bag of spanners it's on coilovers all round and inhabe fitted and anti roll bar but it's still aweful. I have a a lot of camber on the front to fit the wheels under the arch could this be it or am I missing something somewhere
    Thanks
    Paul
    chippy shoulder Admin
    Nov 1999
    Crowland, The Dirty North
    35,414
    18 Post(s)
    How hard is the damping set? What are the spring rates? What tyres are you running?
    what specifically is bad about the handling? Understeer? Scrubbing(same thing really), oversteer? Unsettled? Low/medium/high speed cornering feeling a bit strange?
    Feb 2007
    16,486
    Iirc you run a c20let dont you?
    Oct 2007
    260
    It's at any speed really just feels sloppy runing spax at the front and gaz at the back don't the weights will find out. Running toyos all round and mainly under steer. You running c20let but this isn't when you boosting just normal driving its all over the place
    Mar 2008
    SE London
    4,406
    check all the bushes front and back. ( suspension arms, tie bars, top mounts, anti-roll bars, ball joints )
    you might have some worn parts, causing it to wibble-wobble its way round corners.
    if everything is spot on, it might just be the engine. the c20let is quite weighty on the front end, which upsets the 50/50 balance further, and promotes under steer
    Mar 2008
    SE London
    4,406
    i wonder what its like to drive a 3.3 turbo porsche, with all the weight at the back.
    i heard somewhere they lined the front bumper with led to try and help the handling
    Oct 2007
    260
    Cheers guys al have a look was thinking of putting a polybush kit anyone tryed this is it worth doing
    Jun 2007
    cumbria
    953
    Novas just dont handle like a decent new car
    23,813
    Correct/better spring rates will help alot.
    Polly bushing i found makes everything feel tighter.
    Not being to low helps, unless you start to correct things related to that.
    Jan 2003
    SOMERSET
    19,510
    Quote Originally Posted by paul burney View Post
    Thats the problem. Mis-matched suspension.
    Once upon a time I had KONIs up fr & Avo on the rear, the car felt so dangerous above 50mph I literally didnt have the bottle to take normal A-road bends at anything like the speeds a Nova should do with ease. I was convinced it was something major & not my choice of suspension, however a full set of GAZ's corrected the issues entirely.
