Ok i need some help as i cant make out where everthing goes from haynes photos
I would be really greatful if anyone could post some good photos showing were everthing goes (I.E dizzy vacum lines fuel flow and return lines etc...)
Thanks guys
Thanks guys
^^^ did you just read that? what a idiot ^^^
PROJECT 2 FAST 2 FAT clicky
''lifes what happens, while your busy making plans''
looking at it, stood, from the front of the bay, the fuel line IN, is at the back right hand side top corner of the carb.
theres 2 vacuum pipes at the backside of the carb, at its base, one is dizzy vacuum, and the other i think is the choke pull-down (big black, weird looking plunger thing)
the secondary throttle vacuum is on the frontside of the carb, at the lower left, and has a short hose going straight to the vacuum unit on the front
depending on your setup, you may need to blank 1 of the vacuum pipes to seal it up
explaining that a bit better :
the 2 vacuum pipes at the backside base - the one on the far left goes to the dizzy. and the one in the center-ish, goes to the lower half/side of the choke pull-down unit, and then another hose comes out of the upper half/side of that unit, and goes into that little round black biscuit looking thing / electrical cut off thing, on the front right corner of the carb.
Great stuff cheers mate. i will have a crack at it this weekend....but expect some photos as im sure i will still get confussed
