Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 93
Thread: my first nova build
  1. #41
    2,618
    That angle grinder must be like swinging a dead lamb about
  2. #42
    Apr 2011
    N.ireland
    216
    Only tool u need lad, bigger the better
  3. #43
    Apr 2011
    N.ireland
    216
    Decided now to go down the route of a redtop so time to strip again to be seam welded, hopefully this should make it a more interesting first project goin to try keep the thread updated a bit better now too do more progress to follow tomorrow hopefully
  4. #44
    Apr 2011
    N.ireland
    216
    Got my redtop engine home tonite there time to get it stripped out and get a few things done to it before it goes in
  5. #45
    Apr 2011
    N.ireland
    216
    Started to remove the engine the nyt, hopefully have it removed tomorrow nyt, just learning as I go as this is the first time I've tried anything like this
  6. #46
    Apr 2011
    N.ireland
    216
    Got the engine out of the corsa the nyt so time for the strip down and clean and a bit of freshen up, while I've it stripped down I'm goin to give the head a rebuild and the port and polish it and skim it then Al new gaskets and seals
    Also got a few bits gathered this week
  7. #47
    13,604
    Good plans with the XE to give it a refurb, although I wouldn't try a DIY port job if that's what you're thinking. Don't forget to have the crank out and measured up.
    You may want to use an OE XE sandwich plate instead of that shiny blue one as it has a thermostat switch inside to bypass the cooler.
    Worth getting the larger radiator in there for a bigger engine.
  8. #48
    User gary_126's Avatar
    May 2002
    Argyll, West scotland
    902
    comming along well!
  9. #49
    Apr 2011
    N.ireland
    216
    Naw I'm goin to send the head away to get done, wot do u mean by measure up the crank?
    Yeah still have the one here that came off the oil cooler that came in it, wot type of radiator suit I get?
    Sorry for all the stupid question its just the first time I've done this so I want to do it right
  10. #50
    Apr 2011
    N.ireland
    216
    Quote Originally Posted by gary_126 View Post
    comming along well!
    Thanks lad,
